Post your 10 second combo's
While that is cool, I could build a hell of a nice/quick car for 100,000$
Wednesday night results. Another 2nd place. dialed 10.62 rand 10.63 but, I blew the final round with a bright red light 0.017
Wed night results. 10.62 on a poor preped track. The worst part my motor broke. Not sure yet what happened but it looks like a rod through the block. Sick visual. water and oil on the track.
THAT SUCKS!!! Post carnage photos if you can. Hope crank is ok.
WE FEEL YOUR PAIN !
When I blew up my 440 motor (rod right thru the block) it was the "excuse" I needed to build a new 505" stroker motor.
So sorry to hear that. Ron
WE FEEL YOUR PAIN !
Ditto! I had been collecting parts for my 505 when the 440 shot craps. It just sped up the process..
Well I got the car in my garage and got a look at the block. One hole near the dipstick. thats as far as I got with it. going to pull the engine in a few days and tear it down. I will have parts for sale soon and I am going to buy a complete new motor. Just not sure yet it may be. I have been talking with a few guys and indy heads. I will keep you all posted as to whats on my list for Christmas and what parts I will be selling. At least this all went down in the final two weeks of the season so no pressure to hurry.
crap sorry to hear that
Tex
Tex
Going to build something just not sure where I want to go with it. As a bracket racer spped is not the issue but it's addicting. I was happy with a 10.5 motor but, it's tempting to kick it up a knotch.
THE NEED FOR SPEED !!!!
I just checked with the Hughes Engines web site and see that the Edelbrock RPM heads can be CNC ported FROM 275cfm, which is out of the box (@600 lift) TO 328cfm (@600 lift).
That work cost about $775 plus about $125 UPS Each way from Cal to Illinois and back...total $250 for both heads out and back.
The Edelbrock MAX WEDGE HEADS (which are the ones that you do NOT have) can be CNC ported TO about 380cfm (@600 lift). They flow 310cfm (@600) out of the box.
INDY SEZ standard port heads (which are the ones that I have) flow 290cfm out of the box.
Heres the next deal I am serious about. I need some thoughts on this. I know the builder and he is a good engine builder so thats off the table. Here are the parts.
511
400 factory block
Main girdle
ARP main studs
Eagle 4.25" stroker crank
Eagle Rods
Ross Pistons
Clearances are .0025-.0030/.0030
Clevite bearings and Total Seal rings
All balanced of course
Muscle Motors ext oil pump
Dragster pan
Compression ratio is a bit over 12-1
Comp Roller .730/.730 lift 284/288 @ .050
Comp lifters
KB Gear Drive
Indy 440-1 heads with full CNC port flow [email protected]
T&D rockers
Pac Springs, retainers, locks and caps
New 2.25/1.88 Manley Valves
ARP Head studs
Trick Flow pushrods
Fel Pro Head gasket
Indy 440-3 Intake, Dominator flange
511
400 factory block
Main girdle
ARP main studs
Eagle Rods
Ross Pistons
Dragster pan
Comp lifters
KB Gear Drive
T&D rockers
ARP Head studs
Trick Flow pushrods
Fel Pro Head gasket
Sounds great....why not go to 13.5-1 ? also 1.6 rockers ? . Also steel billet main caps.
Like you have the motor listed it is way north of 700HP...probably 775 or so.
yes around 800 hp. the motor is all complete and fresh. I may need to slow it down some.
well you know the faster you go the more exponentially it costs as well wear and tear plus maintenance goes way up .
I finally have my short motor together . 1 round left in track championship and o/seas holiday then motor out in December , service and reuse current heads and sump . I am aiming for 10.50's somewhere . Like you I am a bracket racer so I will leave some HP on the table to maintain reliability , plus I daily drive it around 6-8000mls a year .
Tex
