Alternator question
Hanover Mopar
7:07 AM
Northeast
Output from my 3 wire alternator when running about 2500 RPM is 13.5 volts at the alternator but only 12.5 volts at the rear mounted battery.
Do I look at voltage regulator or what direction should I go. Can you test a regulator.
Thanks in advance
Jack
Sounds like voltage drop from dirty connections(anywhere in circuit) or undersized wiring.
Same voltage at rear mounted battery as at alternator with engine off so I guess I look at connections for the grinch
