Hopefully it's just a defective lifter, and like already mentioned the lifter can be removed with the right type of magnet. The bottom of the lifter may tell the story. Was the cam properly run in? Was Break-in oil used?
Thanks for all the infor. I will post resultsThrough the years I've only had to perform this procedure twice and both times I used a fairly strong parts pick up type magnet with an extendable arm. I didn't need a specialized tool for the job so I can't comment on that. But here is a photo of the magnet that I use if it helps.
What were the results on this?Thanks for all the infor. I will post results
