WTB Speedo pinion for cable shift trans
hemlock
8:59 AM
Chicago
Feedback: 2 / 0 / 0
I'm looking for the early style speedometer pinion with 20 or 21 teeth for a cable shift trans.
pretty difficult to find. a ratio reducer is an option but not cheap.
Have the ratio reducer, and you are correct, not cheap. Probably not many 21 tooth gears around, have never actually seen one, but figured I would post an ad anyway. You never know
i use a ratio reducer. never seen a 21 either but do have a 20 i stumbled on. you can do some juggling with a reducer and 17-19 tooth pinions which seem to be easier to find.
I don't know exactly what I'm going to use for rear tires yet, so I can't nail down the pinion exactly. I have a 17 and a 19 tooth and the ratio reducer, just want to cover my bases so I'm not scrambling when I do decide on tires
a lot depends on the reduction percentage of the reducer.
