Bruzilla
- 10:47 PM
- Jan 11, 2012
- Orange Park, FL
Okay, I've fixed my carb problems, brake problems, exhaust problems, and electrical problems, and now I have a steering problem. There is a lot of play in the wheel. A lot. I've attached a video showing how far I can turn the wheel before feeling any resistance.
The steering was fine when I took it to the shop three years ago. The only changes made to the system were replacing the power steering pump and hoses. The 360 had a Saginaw and the 440 has a Federal. The steering works fine, there's no leaks, no odd noises, but there is all that play in the wheel. When you look at the steering "shaft" it is turning right with the steering wheel, and it looks like where the problem is at is the steering box.
Do I need to replace the box, or is there an adjustment I'm missing somewhere?
Thanks!
Thanks!
