source for red vinyl dye
The 500 Foundation
10:14 PM
Bailey CO
Ok everybody, I have a 68 Charger with the metallic red interior. Im looking for the correct dye for the armrests and the correct paint for the console. So far I have only found the early bright red....any Ideas?
Ok everybody, I have a 68 Charger with the metallic red interior. I'm looking for the correct dye for the armrests and the correct paint for the console. So far I have only found the early bright red....any Ideas?
try your local auto paint shop they mix to what you want mine even mixes 2pak in a spay pak but that needs to be used same day because of the hardener so if you plan ahead it may be an option no heavy spray equipment needed
Check into Duponts' (Axalta) Spectra Master flexible coating series. Some 4000 colors to choose from.
Herbs is an exact match to Mopar only colors.
Ok I finally get to help someone. I just learned this as I was resolved to use maroon red on my interior as I noticed that pretty much all the 68,69 mopar red interiors that have been redone have a orange hue which looks bad to me in redoing my seat covers from pui I had to match the headrests which I had dyed SEM Napa red a maroon did not want that orange hue. So they were darker than the new seat covers ( metallic red pearl). Since I had several spray cans of SEM portolo red( orange hue)left over from my color trials I decided to try it over the napa red. Came out perfect! , finished off with vinyl chrome molding 1/4 , they look brand new and a perfect match to the pui new seat covers. Note : if sprayed over a light color such as grey primer, the portolo red will have a bright orange hue, use SEM napa red as a base coat next will be a little pearl I will get from a plaster figurine paint store( can be dabbed on a piece of cotton and rubbed on. Hope this lesson of mine helps I can only wonder about all the mopar show cars with that orange hue interior
I am now using those cans on all my interior plastic and console, looks so much better than maroon.
A true Original interior other than black/white is NOT one consistent color.
Different vendors were used and there will be variations in color, sheen, texture etc....
The worst one with these variations was Red interiors.........
I agree, but there are tricks with color matching such as I learned in this case
