Sill plate 63 Fury
jball1105
7:35 AM
Ogden, UT
Hey guys. Working on installing new carpet and I think I am missing some parts for the sill plates. Is it two pieces on each side? Any photos would be great. Thanks!
there is an inner and outer the inner holds the carpet in hope this helps
Thanks Mr B. Does the carpet go all the way to the outer piece or does it stop under the inner?
The carpet stops at the body seam under the inner sill plate. The inner sill plate has an arch that goes over that body seam.
You don't have to use an outer sill plate if there's no holes for it. Or you can use an outer one and drill your own holes.
Here's my 62s, No holes for an outer. It's also showing the wiring harness shield.
Is that some kind of seal or wind lace over the pinch weld next to the wiring harness shield?
If you don't already have both inner and outer pieces you might be shocked at the prices. Used outer plates seem to be more abundant but inner plates, not so much. Reproduction ones, if you can find them are north of $300. Used sets aren't far behind.
I have a pair of the outers for sale, $95 shipped.
There's a 63 fury at the local junkyard that I'm hoping uses the same sill plates....? I've got one outer and that's it
I have one extra, $50 shipped.
Kramer's and everyone else to my knowledge is out of stock...
Sure glad I got mine when they first came out...lord only knows when I'll be ready to install them...
I think Laysons got some in recently! they advertise on here also!
