Looks normal to me. DVW seem s to be the expert. Noticed a small opening in first picture upper left corner in Post #98 looks made that way? that's where torque converter control valve I believe is.
Sludgy...probably fine particles off clutches, or rings."Sludgy"--maybe a little "blackish" fluid. All the sharp edges on the valves are to stop particles from getting where they don't need to be.
Have we found the source of the whine?
Local trans wholesaler or try Prndl123. Used will be fine. 3 pin is fine. I run a 3 pin behind 900 hp. I probably have some 4 pin. What year output shaft is yours?It may not quiet it down a lot but at least maybe the sound of the whine will change for better or worse.
Yes - I've never dived further into one than a filter change and once to reconnect the throttle valve lever that came disconnected on the valve body. I was going to just pull it and take it down to a transmission shop but everyone sort of dared me to just rebuild it myself. I figured what the hell - I'm rapidly sneaking up on 66 years and haven't ever torn one apart before so better do it now.So AR67 was this ur 1st tear-apart? Can't remember.. Not as hard as it looks; don't go crazy with the 2000grit!!
I ran into the same thing, on my current build, two years ago, and also the real proud prices on new ones.Having a tough time finding rebuilt or new 4-gear front planetary sets - anyone know of a supplier? I can find new steel cage 5-gear sets but they are about $350.
Guess your wanting to re-use your driveshaft?Also having a heck of a time finding a new, stock 727 sliding yoke for stock 1330 u-joints. Most of them I find are for either larger 1350 u-joints or inside clip u-joints. Anyone know of a source for them?
Could use a 1350 yoke and buy a combination 1350x1330 u-joint. Don't know if you have to re-balance drive shaft. What came out of car? Those 1330 yokes I think are tough to find.
