Tilt wheel
popslavaz
5:53 PM
Channahon IL.
Did '71 b body cars come with tilt wheels? Been searching for column shift tilt.
POPS
Not to take over thread. Any tilts for sale ? I'm disabled and 6'4 . It can be tough getting the right knee in and out. Please PM me with any leads. Thanks everyone
What year is your b body? tilt wheel options were common after 74. For starters recommend purchasing a spare 71-72 column. The 71/72 center shaft is shorter , consider modifying a Cordoba shaft. Maybe able to use later year wiring harness, but worst case you maybe able to use your original hardness.
The other option is to locate a early C body steering column. tilt wheel was a common item on the 70-72 new yorker.
If your successful, send out some photos
the only one in a 71 i have ever saw was in a
71 charger se 383 auto column tilt w cruise control.
so they are out there,but extremely rare/hard to find.
Thanks for the information. The column will give me something to hunt for at the Nat's
POPS
It is a GM column supplied to Chrysler. It has a wire harness pigtail to go from GM ignition switch to mopar at dash harness.
