vegiguy
I'm trying to get at the ignition switch of my '73 RR so I can replace it but I cannot for the life of me get the part of the steering column it's in off. Is this housing - which has the upper steering shaft bearing in it - supposed to slide off of the steering shaft when the three #10 machine screws that hold it in are removed, or does it take a special puller to get it off, or is there something else that has to be removed to free it up?
I thought it might have a snap ring on the steering shaft hidden by the rubber upper bearing seal that needs to be removed first, but after studying it carefully I can't see any such thing. The only other thing I thought is that the ignition lock cylinder might need to be removed in some mysterious fashion to get it off. It's a real puzzler and I can't seem to find any information anywhere on how to do this.
Thanks for any help.
