SOLD ( LIGHTLY-USED) "PRICE REDUCED" EDELBROCK 800 CFM 4-BBL. MODEL 1412 MANUAL CHOKE
Al Zangenberg
10:16 PM
FLORIDA
Feedback: +1 / =0 / -0
Hi Gang!
* I have lowered the price to: $195.00/"O.B.O."
(Please see below for the updated, & appropriate S&H rates), & Options... Thx!
(That's $217.00 under Jeg's list new...and $164.00 under Jeg's Reman. list!) ... for Edelbrock Performer 800 CFM Model 1412:thumbsup:
I removed this carburetor from a running 360/727 - back on January 23, 2017 (less than 3-weeks ago).
Carburetor will ship from: Mount Dora, FL. Zip Code 32757
Price: $195.00 - Plus S&H. (see below for rates).
Will package "V-E-R-Y" securely.
Carburetor may well be acceptable as received for immediate bolt-on service, as it has been just over two (2) weeks since its removal...no gas in fuel bowls.
Private Message me - with email address, and/or Phone Number. (much easier & quicker), via phone! (Thank-you) :)
Payments Methods:
1. PayPal "Friend-To-Friend" (Only F-T-F).
2. Bank Cashier's Check
3. U.S.P.S. Money Order
4. Personal Check (Has to clear, before shipping).
S&H Cost: $13.60-via: U.S.P.S. Priority Mail 3-Day Medium Flat Rate Box (United States Postal Service).
Carburetor weighs: 9.1 lbs. - so Med. Flat Rate, is the way to go...:thumbsup:
Same price to anywhere in the U.S.A. (48 Contiguous States) NOT Hawaii Nor Alaska.
Fastest, Safest, & Least Amount of Handling!
Comes with $50.00 free Insurance, & Tracking Info.
If you want additional Insurance for the entire am't of purchase: (Insured for $175.00)...
Cost: $3.35
If you want Signature Confirmation - Cost: $2.90
Cost: $175.00 + $13.60 S&H w/free $50.00 Insurance: $188.60
Adding Extra Insurance, (for $175.00) @ $3.35 Insurance Cost: $191.95
Adding Signature Confirmation (to above) @ $2.90 Cost: $194.85
* That's below $200.00 (including extra's!)
Your Choice...
Please Watch The Video Link-HERE:
Please see pics of Carburetor!
This Model1412 Edelbrock Performer 4-BBL. Carburetor, has the following:
800 C.F.M.
Manual Choke
AFB (Edelbrock's version of the AFB), is their Performer Series.
(Jeg's) Lists this as a Secondary Type Air Valve, for Manufacturer's Part Number:
1412...
Carburetor Flange: Square Bore
Without EGR
Finish: Ball Burnished
Usage: Street/Hi-Performance
Throttle Linkage Type: Universal
Fuel Inlet: Single (Pass. side)
(Jeg's) Price New: $412.36
(Jeg's) Remanufactured Price: $359.28
(Jeg's) Rebuild Kit (the complete, & good one) Part #350-1477: $39.95
(No Ford/Mopar Kick-Down). If you are going to use this for a Mopar Engine & Torqueflite, you must purchase the following (separately):
(1) Throttle Lever Extension (Holley P/N 20-7) &...
(1) Throttle Lever Stud (Holley P/N 20-67)
(Available through Mancini Racing, & many other outlets).
These must be used for your Trans Kick-Down Linkage, & in conjunction with a Return Spring - for Transmission Line Pressure, & one for Accelerator Return.
Specific Applications will vary...
I needed (and used both the above parts), on the replacement Holley carburetor.
:thankyou:
AL :thumbsup:
100_6373.JPG 100_6377.JPG 100_6379.JPG 100_6378.JPG 100_6380.JPG 100_6383.JPG 100_6384.JPG 100_6375.JPG 100_6381.JPG
MISTAKE MADE
Your wrote Air Valve Secondary AVS
"AVS (Air Valve Secondary) circuit"
This carb pictured is a Edelbrock Performer "AFB" & not an "AVS"
MISTAKE MADE
:BangHead: You may well-be "Kay-Rect!" (sir). Thanks! "rumblefish360" :eek: Jeg's shows this with the: "Manufacture's Part Number 1412", as a "Secondary Type Air Valve" I see the rod from the Primary Circuit, connecting the two "Butterflies" - in the Secondary Circuit. That's an AVS (I thought), as I don't see any Discharge Nozzles, in the secondaries. Hmmmm....? :wtf:
AFB (Aluminum Four Barrel). Carter started this series in 1957, to 1971.
AVS (Air Valve Secondary). Used from 1966 thru 1971. Features spring loaded air valve above secondary bores.
Edelbrock produces new AFB's & AVS carburetor with minor changes. Edelbrocks version of the AFB is called their Performer Series. Their AVS version is called Thunder Series. :rolleyes:
:thankyou:
AL
it is an AFB type carter. the edelbrock AVS's, and all mopar and chevrolet factory AVS's had an adjustable air valve similar to a choke blade attached to the carb top vs the weighted "air valves" in the carb body for AFB's.
so, paypal only?
Yea man! No harm no foul!
Just making a note.
GLWS
Oh, none of the Carter/Edelbrock carbs have the squirter nozzle in the secondary side. IF your crafty, you can add it.
so, paypal only?
lewtot184, Thanks for the additional information; I stand corrected. I'm willing to accept a Bank Cashier's Check, a USPS Money Order, or a Personal Check...
Thanks again!
AL :)
For the record... Jeg's Listing is as follows:
Edelbrock 1412 Details
800 cfm
  • Calibrated for high-performance street (Calibration Kit #350-1480 is applicable)
  • Use with Perfromer RPM, RPM Air-Gap, Torker II, and larger cubic-inch Performer applications
  • Outperforms competition by 26 ft/lbs TQ and 22 HP on a SB-Chevy
  • Features high-capacity accelerator pump and high-lift boosters
  • Comes with .113 Primary, .101 Secondary Metering Jets and .075 x .047 Metering Rods
  • Choke Kit #350-1478 is applicable
Specifications:
CFM: 800
Type; Automotive
Four Barrel
Choke: Manual
Flange: Square Bore
Emission: Without EGR
New Or Remanufactured: New
Carburetor Flange: Square bore
Ford Kickdown: No
Fuel: Gasoline
*** Secondary Type: "AIR VALVE"
Fuel Inlet: Single
Manufacturer's Part Number: 1412
:drama:
Price Lowered to: $195.00/O.B.O. :D See Listing For Details...
