- 7:08 PM
- Oct 16, 2014
- Salisbury, Vermont
SEMPER- FI.
I was thinks 10 and 11 inch drums may be wrong thoughAll 66 chargers had drum brakes. Calipers on the front would indicate a disc brake conversion, so you would need to determine which parts were used. If they came off an A-Body which used to be the most common(dart, duster etc..) or some aftermarket swap. That could be tricky. Almost all cars had 10" X 2-1/2"drums (8-3/4" rear end gear). So the rear brakes should be an easy replacement. Take some pictures of the front and post them. Someone here can identify them I'm sure. Brakes are top priority.
Change all the fluids, hoses (particularly the power steering hose) and belts. Get a clear fuel filter and watch it carefully. But make sure to get some test drive time in before any longer distance driving.
Good luck! It can be done.
Hi everyone, im 18 and fixing a 1966 charger so I can drive it before I go off to boot camp and then to service, I want to get it going hopefully this spring break, and I have a list compiled a long list of materials/parts that I know ill need and material/parts that I might need tot make it run & drive and what not. What i'm wondering are there any places that have "cheap" parts it put cheap in quotations because no part is ever cheap but i'm sure you know that, I was just looking online at one parts store and so far my bill is almost $1,500 I was going to "shop around" at different car parts places but that's with every damn thing I could possibly think of that could hinder it from running... i'm not looking for top of the line parts cheaper the better for right now because after service i'm going to rebuild everything. I was just online looking at some other sites and CARID had calipers for $80 vs the other parts stores at like $130 I know that it just one part but that 50 bucks cheaper... are there any other cheap places I should check out and is CARID a good site to buy parts off of?
I also live in Mosinee Wisconsin 54455
The more info the better always open to suggestions.
sorry for it being so long got carried away kinda...
Thanks for taking the time to read this and possibly respond.
Jesse
Do u have a center grille piece? Mine is in two pieces. Also a trunk lid weather strip.I have a great deal of still new for sale, reason>>I have decided to upgrade to rack and pinion/large disc brakes on all four etc. Plus am parting out 3 66s, will sell all the brake/shocks/frontend parts for what paid and only add shipping costs......I live in SE Iowa
I do, unsure of condition will look at closely, far as trunk lid weather strip are u talking that piece that goes completely around the trunk lid closure ?Do u have a center grille piece? Mine is in two pieces. Also a trunk lid weather strip.
Well when taxes come back ill have tot contact you about some body parts I may need... as for the new parts do you have pictures of them?
Ok thanks. GhostThe new parts I have are only brakes/complete front end steering components,F&R shocks..........No body parts and I may have misunderstood about trunk lid weather strip, I do have one for the 66 Charger, going to use it, Will add,( try) pic of grill today, unless pitted...........
