Stuck Inner Tie Rod End
Charger21
7:30 AM
Iowa
Trying to get inner tie rod end loose on 73 Charger. Tried leaving nut on end and smacking with a regular sized hammer with no luck. I Sprayed it down with PB blaster last night and let it soak and I am planning to try again tonight. Thought about heating but it is covered with PB Blaster and I have a significant power steering leak so don't want to catch it on fire.
Any suggestions? I plan to replace the inner tie rod end and the sleeve but have already replaced the outer tie rod end recently.
Thanks!
Persistence with the hammer blows usually works. Pickle fork, but you'll need a new seal, which might be hard to find. Sometimes holding another hammer or something on the opposite side while smacking the drag link with the hammer.
Smack it on the side with a good size hammer!
Hasn't anyone heard of a "teo legged" puller. Do you really think dealerships service departments used your tactics? I think not.
....and usually use the complicated tools, after the primitive-pete method fails.
In order..... #1 use a bigger hammer, #2 keep a fire extinguisher handy and use a torch, #3 try a pitman arm removal tool from AutoZone/Advance/etc. The one that looks like a "U" & has a large bolt in the center.
Pickle fork. Couple hits it'll come right apart.
Use the force young Jedi!
What PurpleBeeper said. A combination torch, pickle-fork, hammer will do it. Just have all the safety precautions right next to you.
Just get mid-evil on its ***!!
Thanks for all the help. I will give it a try today.
Having done this a gazillion times: 1) whack end with a heavy-head ball-peen hammer (not a wood/nail hammer). 2) pickle-fork. 3) use a puller, which is really the correct way and they're not expensive, every tool box should have one.
Actually, yes. After a whack or two, then it went to plan B, then plan C. But, yes, the puller is the correct way to do it.
This kit from Harbour freight has the right puller for tierods with no damage Pittsburgh® Automotive - Item#62789
they do not seem to have separate but a good investment
