FOR SALE 1969 Plymouth GTX A36 Performance Axle Package with Hemi Suspension
flamed34
9:42 PM
Raleigh NC
Feedback: +0 / =0 / -0
Please read the entire ad before asking questions. I don't need to sell, but decided it will be a while before I get to it as I have other projects that I would rather do first.
I have received the expected "you want what??!!!??" emails. My reasoning for the price is simple - very few unrestored cars are as solid as this. Sure, you can find one cheaper - but then spend $10,000 on sheet metal and labor. Go to AMD and add up what it costs to buy quarters and wheel houses, fenders, door shells, roof skins, inner and outer rockers, trunk pans, floor pans, frame rails, trunk lid and trunk gutters....and then factor in labor, yours or others. Add in the cost of buying a non-smoking, good running 440 or rebuilding a basket case. Add in that the interior bucket seats and rear seat need a good cleaning to be useable. Add in a real N96 hood and upper plenum....
True RS23 GTX
Non-Original, but great running 1970 (F Code) 440 CI Engine. Maltese cross and X indicates .010" undersized crank. Upside down C indicates special crank from the best I can determine.
Engine running and walk around:
From the fender tag (details found at http://www.andy440.com/tag2.htm)
594: Performance Axle Package - Hemi Suspension and Handling Package, 8 ¾ rear end with 3.55 Sure Grip, 11" rear & front drums (A36 Package)
093: 727 Trans
D32 Heavy Duty 727 3-speed
917: 440 4BBL, automatic transmission, heater, 375hp,
E86: 440 cid 4 barrel V8 (High Performance) 375hp
R6: Scorch Red
X9: upper door paint black X9
1X Black vinyl top
6W (while stripe below molding in blackout area)
C16 console with woodgrain panel
V21 Performance Hood Treatment (stripes)
26 = 26" radiator
P6X: black bucket seats
ADDITIONALLY:
Non-original N96 Air Grabber Hood and upper plenum. DO NOT have air cleaner assembly.
SUPER SOLID. . ..repeat. . ..Super Solid
Rockers -- Solid
Trunk Floor -- Solid
Interior Floor -- Solid with the exception of the Driver's Side REAR floor. All there, but weak.
Quarters -- Solid. Driver's side has been replaced with a new quarter skin due to damage, not rust, by the previous owner. It doesn't meet the inner structure underneath - have not messed with it to see if it will come together or was installed wrong. Pic of quarter skin to show what was replaced.
Inner Quarters -- Solid
Frame Rails -- Solid
Front Fenders -- Solid
Doors -- Solid. Driver's side inner corner slightly rusted (see pics)
Gas Tank -- New
Exhaust -- New
Seats -- No Rips or Tears. Need a good cleaning but very useable.
Needs typical rust repair around the back window due to the vinyl top. Lead is out of the seam.
Have all tail lights, headlights, bezels. In the trunk along with trim, emblems, etc.
All glass EXCEPT the windshield is broken
MISSING: Bumpers
Drove it on the trailer. Unfortunately didn't realize the radiator brackets weren't on it, so a little rev pulled the radiator into the fan...that's the ringing sound if I manage to link the video....
This is absolutely the most solid GTX project I have seen.
Odometer is showing only 58,673 miles. While I can't verify, take a look at the lack of wear on the pedals.
No Title, but I have run the VIN through NC DMV and it came back clean. I haven't been able to find the time to go through the bonded title process, but it is easy (just did it on a vintage camper a few months ago -- requires a Form MVR-92H, an inspection, and a surety bond).
I have not found a build sheet in the car, but I have not pulled up the front seats or rear side panels.
Asking $15,500
I don't see a price? Maltese cross (I thought meant water tested) That looks like an X .maybe I'm wrong?
Sorry...added the price.
The Maltese is just before the X. I found the info on several sites, but here is info on the Maltese Cross and X: http://www.andy440.com/tag2.htm
So it's up to the buyer to get title? Looks to be a great candidate for restoration, but the lack of title is a roadblock to say the least. You may be money ahead to go through the trouble to get title for buyer
I agree...my problem is time. I've recently been given two more departments at my job which = tons of hours. Finding time to get off to meet with the inspector for NC DMV isn't something I can do right now. For someone in NC, the process is easy. We did it in the fall for a very rare vintage camper. Several other states are easy as well.
I'm not desperate to sell. If I find the time, I'll go through the process. Or someone who wants a super solid, mostly complete '69 GTX who knows the process in their locale can get a great project.
Ok I had to zoom in! Yes you could be right I forget but I had a Hemi block with the cross and the crank was .010, It was water tested too.GOOD LUCK BROTHER!!
UPDATED: After pulling it out for a showing and emptying out the trunk, it was realized that both rear quarter skins have been replaced with NEW and the trunk pan has been replaced with NEW. I had never pulled everything out and only believed the one skin had been replaced.
Front.JPG Front1.JPG FrontDrive2.JPG FrontDrive3.JPG FrontPass2.JPG Hoodup1.JPG HoodUp2.JPG
