- 9:00 AM
- Dec 4, 2009
- Pasadena, Texas
Getting 14 inches under 1000 rpm ain't bad but can you really tell by ear if it's 800 or 1000? Would also like to know if the cam was degreed in at 106 and what your static compression ratio is and cranking PSI. How does it act if you give it more timing? Does it smooth up any? Will it ping with more? Even without a load on it, you can sometimes hear an engine ping when you quick throttle it if the timing is too much. I ask about compression and cranking PSI because engines with low numbers generally like a lot of timing.....
