Finished checking my lifters for rotation and went to put on the new timing chain set from Summit so I can degree the cam. Here is the new set... https://m.summitracing.com/parts/sum-g6606r-b
The cam sprocket would not go on with the cam installed. 2 of three bolts would go in but the 3rd was off center. I had to pull the cam out about 3", get the sprocket in place with the 3 bolts, align the marks and tap the set onto the cam/crank snout. Pushing in on the chain with my finger yields about 1/16" give, 3/32" at most. Seems strange to have to pull the cam out to get the set on. Suggestions? Am I paranoid?
Block was not align honed so I doubt any machine work on the bottom end is the cause.
