Kickdown linkage question
Sonny
12:11 AM
Florida
I have a 1970 318 with a 904 (I think) original trans. Does it hurt anything to not use the kick down linkage?
You NEED the linkage for sure. It regulates line pressure, the trans will burnup if not there. If you dont have any look to Lokar for an aftermarket set up.
Thanks! Just replaced my 2 barrel with 4 barrel and intake and now it doesn't reach (working on an extension rod). Can you point me to instructions on how to set it up?
My 2 barrel had the forward end of the slot against the carb connector but pics I've seen has the rear of the slot at carb connector? Here's how I found it:
Try your local hardware store for a threaded sleeve about 2'' long. That's what I did.OR Edelbrock makes one from Summit or Jegs. Your photo is a wrong set up for sure.
From what I read, you:
-Pin the gas pedal to the floor
-verify throttle is wide open
-push the kickdown all the way to the fire wall
-adjust rear of kickdown slot to the wide open throttle arm position
-make sure kd has its own return spring
-release pedal and make sure throttle closes.
Is that correct?
Thanks for all the advice. Great site!
Is that correct?
That may be one way to do it but that's not the correct way. At least, not according to the FSM.
-Pin your carb linkage/intermediate rod bellcrank with a 3/16" drill bit.
-Adjust the threaded ball socket at the top of the intermediate rod so that it clips to the bellcrank with very slight downward pressure. Connect the intermediate rod.
-Remove the drill bit then disconnect the clip, washer and return spring from the carb linkage rod.
-Adjust threaded portion of carb linkage rod until it just slips over the attachment point with no forward pressure on carb linkage.
-Reattach washer, clip and return spring then verify all movement of linkage does not interfere with operation of carb.
-Test drive and adjust as necessary.
Thanks! Not sure I follow "pin the linkage with a 3/16" drill bit". Do u have a picture?
There are holes in the bellcrank which connects the throttle rod to the intermediate rod. Disconnect the intermediate rod, align these holes and insert a 3/16" drill bit.
Do you own a Factory Service Manual?
This is a big block linkage but the adjustment method is the same. You can see the holes in the bellcrank in this photo.
Simply leave a slight gap between the pin and the slot! No pressure on the pin! You'll be very close then drive it allowing the trans to shift, 1-2 shift around 15mph 2-3 shift around 22 mph!
The pic you posted shows the slotted arm and spring in the wrong position. The spring should pull the slotted kickdown lever towards the front of the car. In other words, where the slotted rod goes on to the carb throttle lever, it should be at the back of the slot, so when the carb lever moves, it moves the kickdown rod at the same time. You could go to search, and look for factory service manual. I downloaded one for mine, and it's helped alot.
Throttle return spring looks over stretched. Diagram from my mopar 70 service manual. Looks like rod from bell crank is to short. The the pin should be at the other end of slot. Trans will slip!!!!/Burn up.
Throttle return spring looks over stretched. Diagram from my mopar 70 service manual. Looks like rod from bell crank is to short. The the pin should be at the other end of slot. Trans will slip!!!!/Burn up.View attachment 406490
Thanks for the pic. Found the info in the manual. I extended the kickdown rod with (2) 5/16 x 18 couplers, threaded rod, and threaded the original rod the same after cutting it in two. Test drive Tomorrow! Thanks for all the help!
Is it true with a manual valvebody you don’t need kickdown linkage?
67coro you are correct. Now I’m trying to figure out how I missed this thread. Manual valve body is full trans oil press all the time.
Good to know, I was dreading doing the kickdown linkage lol. Thank you
Now I’m trying to remember where I saved my linkage & put it back on when drag racing days were over? Guess I hid linkage good enuf for the better-half to not find it when doing her quarterly garage cleaning!
