Cam Options for 408 Stroker
rt-man
6:32 AM
Massachusetts
Please provide your camshaft recommendations.
Going in to my '73 SSP. LA block, Hughes LA style Indy X heads, Edelbrock Performer 318/360 intake, 1970 340 HP exh manifolds. I have a Carter 750cfm AVS carb that I'd like to use. Need enough vacuum for PS, PB. Looking for a mild performer around town, torque monster when I stomp on the accelerator. Internals will be a Hughes 408 stroker kit, targeting 9.5:1 CR.
Thanks much.
Sorry to ask this but I need some clarification on;
What is a SSP?
Are the Indy X heads ported?
Do you intended to use a stock converter? Or is this a 4spd car?
What is the gear ratio & tire size
What is a SSP?
Satellite Sebring Plus
Heads will be ported by Hughes
different converter (360 torque converter MP P4876877)
3.21 gear, 215/60-15
Thanks for asking
Thanks for asking
If your heads are getting ported by Hughes why wouldn't you have them grind you a cam? One stop shop
What's making you go with 9.5 & not 10.5:1 ? I 2nd giving Hughes a call and would very strongly recommend calling bullit cams and speaking with Lang lee, he's super knowledgable ........also your best bet would be a hydraulic roller probably on a 112 lsa with a 236 / 242 duration and maybe low 5xx lift . . . . I'm no cam expert by any means but Lang lee from bullet cams is a wizard .
IF! The engine is already built, going to a roller cam will require disassembly for oil galley mods.
Slightly more than a beer budget, but not much more. Hydraulic flat tappet, iron heads fall in the budget. Aluminum heads and roller cam are for someone else.
And I don't want to go down the rat hole of "If you're gonna do a stroker motor, then go for the full gusto or don't go at all." Thanks
I got ya. I would still give Lang Lee a call and get his recommendation on a hydraulic flat tappet for your combo
:DI have a mild hydraulic roller going in a 440" small block. It's 262/267@.050 and .700 lift. Plan to spin it 7500 rpm.
LOL @ "mild" cam specs!
Rt-man, I hear ya loud and clear! Well prepared iron heads and a good Hyd. cam can go far.
Like be the song hd of those cam specs !
Thanks much.
The combination of power brakes and exh manifolds says custom grind to me. Give Duane Porter a call at Porter Racing Heads. He's in northern VT.
