Engine numbers
T.mollergren
1:39 AM
Stockholm
Under dist. theres:
D383
6 6
R
what does that mean? D383 is a 1968,
but the rest?
On the opposite side of the engine theres only a 7 stamped.
cast on the side of the lower part of engine 2468130 .11 and under LL
and also a D some arrows and one N also -1
30 5 68
also stamped on the botton next to trany, PT383R25042890 and below that o 3 thats backward.
can somone thell me what it all means?
cast or forge crank?what damper should i have?
is it a HP engine?
Not up completely on 383 cars but I'll take a shot:
D383 is the year and 383ci
6 6 is June 6th
R - no idea.
Casting area with the arrow denotes day shift or night shift.
The PT383... is a code for the following:
PT - plant code I think.
383R - same as above
2504 - Julian date code for June 5th 1968
2890 - sequence number.
Rest of the questions at the bottom of your post - no idea.
6 6 is June 6th
R - no idea. Regular fuel. Indicates the car was a 2bbl
Engine was assembled June 5th/6th 1968.
Since the R tells us it was a 2bbl assembly, it was not an HP assembly. Irrelevant since the block is the same for both HP and not. I presume you will rebuild it to your specs.
Forged crank.
