Glenwood
- 8:09 AM
- Jun 19, 2015
- Kawartha Lakes, Ontario
Guys,
I could some pointers at this stage.
I've filed and assembled the rings which are a moly top ring and cast iron 2nd.
The rod bearings have a hole on one half which I think is for aluminum rods with a dowel. Does this matter on steel rods and should it be top or bottom?
I've read different methods to install the pistons regarding oil soaking vs wd40 and effects on proper ring seating. How does one choose a method here? This part is a bit confusing!
Once two rods are on the crank, how do you determine where the rod should rest? First measure between the throw, then in between the rods and then the 2nd throw? They have floating pins so they have a bit of play. I would expect to try to center them on the pin somehow before snugging them up, but not sure how yhat is done.
Is a stretch gauge really necessary for a mild build or would torqueing be enough?
