Help identifying ignition wire
wsutard
7:49 AM
Seattle
I recently removed my engine and in the process I ripped out a wire that connected to my coil. I can't find the origination of the wire. Here is what I know. I'm hoping you guys can direct me to the wire it is supposed to connect to.
1. I run a MSD 6AL digital
2. Two of the Three wires connected to the coil go to the MSD. The third one is the one in question.
3. The one in question was connected to the negative of the coil.
4. It is green
5. It has a spade connector on the end that connects to the origin point
6. I see no spade receivers on the firewall anywhere around where I remember this wire going.
7. There are a few wires that have been cut and are just hanging out. However, that doesn't nessesarily mean anything about this wire.
8. I am not positive the wire actually went anywhere in the first place.
Help!
I think I figured it out. It was the tach wire from the original ignition setup. Inforgot to remove it. Hence the reason I can't find the origin.
