Glenwood
- 8:04 AM
- Jun 19, 2015
- Kawartha Lakes, Ontario
If your not willing to properly prep the top half of the engine save your money. Run the stock pump and pan and just hope you never need the reserve. Otherwise get the diegrinder out and due the prep. 10 quarts of oil will be of no advantage if it's all stuck in the heads at can not get back to the pan.
I use the high volume and high pressure system with 3/8" pickup and have had no problems with high speed runs in excess of posted speed limits for hours.
The question is do you really need the extra protection of a high volume system and extra capacity.
At runs of 4800 rpm you have less than 5 minites before there is no oil in the pan with a stock 5 quart system.
Where are the restrictions on the top end?
