Mike Gaines
- 6:29 AM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
I have finally got it together to have my Out of the Box INDY SEZ Standard Port Heads taken out to MAX WEDGE SIZE and some porting while at it.
Also a new INDY DOMINATOR BASE MAX WEDGE PORT intake manifold.
Also new COMP springs/retainers/valve locks, seals and valve guides as well as all new Ferrea Stainless Steel valves. Increase open pressure from 350lbs to 410lbs. The cam is broken in from previous runs so we weren't nervous about increasing the spring pressure.
I need the extra spring pressure because I have been going thru the traps at 6800RPM (4.30 gear with 28" tall tires) and now I think it will be going thru at over 7000rpm with these upgrades.
Hope it all makes a sizable difference at the track.
I think I might be the last of the guys to finally go max wedge.
I am certain that I can now run "easy" 10.60's which is the index for my main class at the drags which is D/GAS even in really "bad" air of 3000' to 3500'.
I have an "adjustable restrictor plate" to dial it right onto that 10.60 et index.
I kinda think the car will run in the high 10.20's or low 10.30's right at 130mph in "good air" of around 500-1000 feet adjusted altitude. My personal best was 10.48 at 126.6 in good air (500 feet adjusted altitude) before this max wedge and intake manifold upgrade.
And most important the car is 100% street legal with current California Tags and insurance by Hagerty. (Headlites, horn, turn signals, DOT M/T slicks, all glass windows, fully carpeted, etc)
Next outing is not until June 3th and 4th.
