Lol.Your doubts are incorrect. Ive worked with plenty of aftermarket body panels. Reproductions may have a horrible fit in some cases (not amd) theyre heavier in gauge than the originals . The truth is that these cars are 50 plus years old and have been stressed and tweaked that even with nos parts you may have a troublesome fit.
Im not one who holds assembly practices from any country including the Usa to the highest standards when these vehicles were rotting in under 10 years from when they were made.
Amd is junk that needs to be cobbled together? Hardly. If you think youre Never going to cut , bend, grind and fit an entire quarter panel even if Nos on an aged car such as these then you haven't done enough bodywork in your lifetime. I wouldnt be thrilled to see your work if you didnt do a thorough fitting before welding, whatever brand you used.
i disagree
some of their parts are pure garbage and should never be sold to the public
like the 68-70 b body outer wheel houses that are based off a 4 door wheelhouse
(i had to beat them up really bad before they would even admit it! liars!)
their lack of research turned into a pos part that should of never reached market
it will NEVER fit unless it is cobbed and
THEY DON'T CARE AND WILL STILL SELL IT
because enough people accept crap!
they reworked it to over 4 different versions
btw all 4 versions suck
the last one just has hogged out alignment holes lol
if the garbage was half as good as advertised
i would have no complaints..
to me it is over priced parts of last resort.
restoring something means to me something that resembles original
AMD is far from that.
you must have lower standards then i do
if you think AMD is that good.
i have a brand new AMD trunk gutter that will go in the trash.
looks nothing like a original
nobody will buy it even if i give it away at less then half price
i have never had the fitting issues using nos or used
compared to AMD it is not even close.
when i install a panel,
i don't want to have to  cut,grind,splice or have to add on material
that is cobbing in my book.
