71GTX440
I have a QFT Slayer carb and honestly, it is kicking my butt. I have called QFT (holley) tech support and first they suggested I needed to rebuild the carb. Bought their carb rebuild kit and guess what? Same damn issues after rebuild!
I searched the archive forums and have not found any answers.
Problem 1: When adjusting the floats, I loosen the screw(s) on top of each carb head and then loosen the nut under the screw top so the floats move up/down and line up with the factory marks. Tighten the nut and screw down, start car and fuel bottoms out, car stops running. Loosen screw and nut, raise fuel level higher than factory mark. Tighten nut and screw down, start car, fuel weeps out of the nut/screw position. I have replaced the washer between the carb head and nut and the washer between the nut and screw head (twice).
Problem 2: Adjusting the fuel screws (4) while on the phone with QFT tech support, did absolutely nothing positive. Car runs like it is starved for fuel, no acceleration, just mopes along.
Any help would be greatly appreciated.
