Evans Cooling
moparnation74
7:47 PM
OHIO
I have researched this in the past and I am considering this for my current build.
Before anyone starts I am NOT concerned about cost.....This stuff is not cheap...but for being waterless and a higher boiling point it may be beneficial living in hot Texas!
What I do want is any real world reviews other than the typical reviews on the sellers sites.
Anyone currently running this in their cars?
https://www.evanscoolant.com
I have run it for years and it is ok. It actually runs a little warmer than regular coolant. If you look at the MSDS sheets for it you will see it is not too different than regular coolant. I am using the same stuff that I put in 10+ years ago and it seems to be holding up pretty well.
There has been plenty of opinions on the Evans stuff on this site. Type in Evans on the search menu at the top right corner. You will get a ton of info.
Thanks!
In the sea of threads I found a key thread...PurpleBeeper gave a clear analysis on evans coolant. Good for aluminum and boiling point and that is it...Back to the traditional and purple ice/Lucas and if no aluminum water wetter...
Here:
http://www.forbbodiesonly.com/moparforum/threads/coolant-recommendations.92712/page-3
Great thread....
