1970 K Frame
tnfastback
5:30 AM
East Tennessee
Does anyone know what year K frame will swap on a 1970 RR?? Or does anyone on here have one for sale??
#'s as follows are for Non Hemi or Six Pak
70-71 E-Body & 71 B-Body part # 3583074
70 B-Body 2962090
There are differences and 70 B-Body is by itself
70 b-body is by itself, different than an e. The steering box angle for the up to 70 b is different than the e. 71-72 b&e share the same unit with the 73 taking spool mounts instead of biscuits. Can't remember if 73 on the b is when they used the rubber mounts between the body and k/subframe. Also 70 is when the sway bar passed through the k instead of mounting in front of it. Supposedly you can use the 71- k's but you will need the centerlink to match as the countour is different on it because of the mount angle difference of the steering box.
