I used to change mine quite often.....usually because I was swapping gear ratios a lot and didn't want to chance any dirt from the swap getting in the drain pan. At one time I was using a suction gun but that was a rpita.
I did the same thing but got the same results from both and that's when I tried the STP for the first time in a rear end. First time I used that stuff was to 'doctor' a 69 Dodge pickup in the mid 70's. Hard to believe it smoked so bad when it was only 6 years old but it looked like it was rode hard and put up wet. 3 cans later and no more smoke!
Next patient was a 65 Mustang with a tired 289 but just one can did the trick. Fast forward to the early 80's and now working at Exxon and one night while doing some maintenance work in the lab, I run into this chem engineer and asked about the use of STP. He chuckled at the question but explained that a product that STP uses and trademarked is used in just about all lubricants. Only thing is, the product that most refiners use isn't marketed as STP....and since it's sold only to refiners, it's not marketed to the general public but basically, STP is pretty close to the same stuff. I did manage to end up with a couple of quarts from the refinery and it's even heavier that what STP packages if that can be possible lol.
