Zinc and Knocking
FlagCraig
4:11 PM
Tennessee
Will a lack of zinc in oil cause motor to start knocking?
It's a new rebuild with about 2K miles on it. She's had two oil changes with zinc additive included.
Thanks.
Nope. Alkyl zinc compounds are anti-wear additives used in some oil, especially "high mileage" oil, which isn't a bad idea for engine break-in.
If you have ANY knock at all, I strongly suggest you stop driving the car and figure out where the knock is coming from. Hopefully it's just a lifter that never pumped up causing one rocker/pushrod/lifter to be a little loose.
1. BEARINGS - See if you can connect a mechanical oil pressure gage. If the oil pressure is high, even after warming up, then your rod/main bearings are OK. A spun rod bearing has a very deep-sounding "THUNK, THUNK, THUNK" sound, way down in the engine.
2. VALVE GEAR - If there's something off in the valve gear, you can usually tell that the noise is coming from up top & it's more of a "clickety-clack, clickety-clack" sound....not nearly as deep, low-pitch as a rod bearing.
3. PISTONS - very old school forged pistons often had maybe .008" piston-to-wall clearance which causes "piston slap" until the engine is completely warmed up. My mid-80's TRW pistons do that.
What they all said. If you can provide more details on exactly what you hear, and exactly when you first heard it that would be helpful.
Is this a steady knocking sound, or does it just occur under heavy load?
It was a loose torque converter bolt. My engine builder found it.
Thanks guys for all the input.
