hemiron
Looking to buy a dual point distributor for a 69 hemi charger Chrysler or prestolite. Thanks
I would go that route but with just 10,000 miles on this car that's gone through a complete rotisserie restoration I'm trying my hardest to get it correct. Unfortunately the original distributor disappeared quite a few years ago. What was in a box that I thought was the correct one ended up being for a 70 440 6 pack I believe. Thanks for the reply. RonAll I have are small block presto lights do have this accel tough wich should be 60's era.
I can build it up with all accel parts and run it on the dist machine and blueprint it.
View attachment 432905 View attachment 432906 View attachment 432907
The complete distributor would be great. I have a Chrysler 3438251 IBS-4019B 250 that I thought was for this but nope. Any need for it? Roni can give you whatever you need.View attachment 432919
What do you mean mech advance specs? RonI probably have a 69 RB distributor I can build up if you want and run on my tester. You have the mech advance specs so I can pull one the same?
It's a factory 426 dual carb automatic. Nothing is oversized at all. ThanksYes mechanical and also vac to the way your motor is set up, I do have the factory ones if that is it need to know carb and if it is AT or MT.
I've been told (not verified ) that I need a 2875140 or 2875141 with the IBS-4014A. I'm thinking the IBS-4014 number is what I'm looking for? But I'm definitely not at all up on distributors at all...I have this one that I was never sure about what year it was correct for.
My interchange manual shows part number 2875987 to be for 1970 426 4sp. and 2875989 for 1970 auto. --As you can see this is a cast iron Chrysler 2875981.
I'm not up to speed about what the other numbers on the tag tell.---IBS-4014C 7 9--
I have a 69 coronet hemi 4sp that is a 50k car that has not been "restored" (just refurbished and painted). It is running on an electronic dist. for now and this one was intended to be a spare. It sounds like your place for this dist. may be better than mine.
View attachment 433412 View attachment 433413 View attachment 433415
This is what the manual shows what and how the distributer needs to be. Is this something you could do?i can give you whatever you need.View attachment 432919
I can't find the chart I was looking at so not positive if the one I have is for a 70 or 71. The numbers are Chrysler 3438251/1BS-4019B 250. On the vacuum advance the number is 3438277. Does the distributer you have have numbers on it?I have a mint one for a 70 hemi auto, it came originally on my six pack car.
I need one for a 70 six bbl manual.
I believe yours is for a 71 440+6I can't find the chart I was looking at so not positive if the one I have is for a 70 or 71. The numbers are Chrysler 3438251/1BS-4019B 250. On the vacuum advance the number is 3438277. Does the distributer you have have numbers on it?
