ash tray light
velozp
12:21 PM
massachusetts
Hi guys my ash tray light went out on my 68 RR . I put a 12 v battery on it and its dead. My question is I have it out but how does the socket come out of the case so I can replace the bulb? It was working till this summer Its minor but the novelty is great. Thanks
i changed mine last month,it pulls out from the bottom i used small pair of pliers and just pulled down and socket came out from the capsul,do not squeeze to hard.i like for things to be working as well.
I actually removed the blue plastic light diffuser in mine and solder installed a green 12v LED. No more problems.
Thank You it took a few minutes, some rust along the ground clips, I will clean it up and make it new. Thanks have a great summer
Do you know the correct bulb #? In my book it says its a 1445 fusible link and their is a 1445 bulb avl at most stores but my bulb says # 53. any idea?
