Removing a reverse manual valve body
ws27
9:06 PM
Waltham
I'm buying a car with a reverse manual valve body and I'd like to go back to stock. Does anyone know if this is something I can convert back to stock or if I have to replace the whole valve body?
Sorry, it's a 66 727.
Thanks guys, I'll have to find some extra parts.
I like manual valve bodies.....how hard is it to convert it to a straight shift?
Cranky never really got into that, I sold my 'race' trans & rebuilt another torqueflite I picked up from somewhere. I think I put in a TF-1 kit in it because it shifts pretty darn quick when manually shifting it(it's been a long time ago)!
Cranky my previous answer wasn't correct for your question--- just swap out to a normal valve body.(my manual setup just felt/sounded like the whole drivetrain would lay on the pavement when it shifted(on street driving)) I always marvel at the power that a torqueflite will handle. Originally engineered for 240hp I believe.
The k/d linkage is what I like to get rid of!! Been years since running an auto on the street but even with a stock trans, I manually shifted it and still do.
Yeah but the trans still needs to see throttle position for throttle position. Sounds like it's time for a 4-spd!!!!! IF your left leg can handle all the up&down!!!! It gets old pretty quick!
When a trans is built with a manual valve body, is anything else done to the trans, like passages plugged, removal of governors, etc. Something to know .
Could be, depends more on the intent of the tranny rebuild more than what the valve body needs, though some valvebody builders recommend certain upgrades to servos etc. in conjunction with their VBs.
How does it drive?
How does it drive?
Mine works fine. I have a manual valve body also, and was also thinking of doing what the op wants to do, and was wondering if it's just a matter of swapping valve bodies, or is there more to it?
