You need to say if you have an 8.75 or a Dana 60 and what u-joint your looking for.I need a drive shaft for a 68 Coronet 2dr hardtop with a 727 transmission.
Sorry new to the Mopar stuff.You need to say if you have an 8.75 or a Dana 60 and what u-joint your looking for.
Thanks.Probably a 7260 u-joint. You can buy combination u-joints so if someone a different u-joint you use a combination u-joint, just make sure one is available. The link will help you figure which u-joint you have.
http://www.driveshaftspecialist.com/HTML Measure/UJ ID Guide.html
Thanks for your help and knowledge.You also should know the length you need.
I don't know if rubber trans mount for a 904 is the same as a 727. You should have engine and trans in car before buying d shaft.
