Ballast resistor testing
okay, so with the ECU connected, i get 6.09v at the coil. Engine running 8.36v
The 6.09v is lower than his recommended 7-9v What can i do to increase that ?
That's close to what I have. What is the voltage to the resistor? A smaller resistor will bump the voltage up a tad but it sounds like your in range while running.
I'd have to go check. But, i've relayed all this info the seller of the ECU and he says i'm FINE. So i guess what's important is the running voltage.
Makes sense.
Thanks guys. :thankyou:
