A few questions
The Rebel
8:03 PM
SW CT
Hey guys. Looking to see where the correct placement is for the Door Post Decal.
Also my car is missing 1 of the Pentastar Fender Emblem. I'm a bit leery of drilling into the fender as there is bondo in that area, which is why it's missing. I was thinking of placing a new one there but just cutting off the pin & gluing it instead but wanted to get your opinions.
Also need to get one of the Rallye Dash Medallions but man at $80 that's crazy, so hoping someone else has a vendor that sells these cheaper.
Thanks for the input guys. Moving on I need to get one of the Rallye Dash Medallions but man at $80 that's crazy, so hoping someone else has a vendor that sells these cheaper.
Also looking to see where the correct placement is for the Door Post Decal. I believe it's on the drivers side door on the front by the hinges. I'm assuming the type faces into the car but again need confirmation.
429273-7723924ce9f9713204860ae80e787976.jpg 429274-1580409963d93fdf780b824d4c5d47c9.jpg
Interestingly enough, what I thought was a pc of tape in that area was in fact the orig. door post sticker that someone had painted over & put a hole in it to run a speaker wire thru for an aftermarket door speaker. I was able to scrape the paint off with a razor blade and as I was doing so noticed that the orig. one did NOT have the Pentastar on it like one CI sells. I'll be staying with the orig. one. If it isn't correct then it's not going on my car!
I was looking at these Rallye Dash Medallions on Classic Industries but there also very expensive.
Looks like these were used on '68 models only?
