- 8:38 AM
- May 14, 2011
- On the Ridge, TN
Real quick, the particulars on my car:
'68 GTX with a mild rebuild 440 with a 484 Purpleshaft in it. 4 speed, 3.55 SureGrip.
Edelbrock 1407 750cfm carb, right out of the box set up.
Everything is fresh, including Centerforce Dual Friction clutch.
Car actually runs and drives very nicely. Mixture screws set for best vacuum and the car likes the accelerator pump on the furthest out hole/setting.
Mopar electronic ignition conversion. Timing is set to give me a mechanical advance total timing of 36BTDC which comes in around 2500rpm or so; that gives me an initial idle setting of about 13BTDC. Vacuum advance disconnected for now - it gets jittery/surges on part-throttle acceleration if it's hooked up, which I know I need to play with/adjust eventually.
Car idles just fine at 800rpm, too.
Now that the combination has gotten some miles on it, it's time to tune it more.
It pulls just fine as it sits, but I feel that it's not pulling as hard as it could/should based on my past experiences with other 440s.
Don't get me wrong - it doesn't stutter or fall down or nose over or anything, it's just not as hard a puller as I think it should be.
Before I start playing with the carb to richen things up (which I know it needs because it flat hates it if I move the accelerator pump rod at all towards leaner), I just wanted to make sure that the timing is pretty much a done deal?
FSM says to get 38BTDC so I'm pretty close with that now.
Does the vacuum advance actually do more than make for better part-throttle cruising fuel economy?
