Rear body brake line to rubber Y block line 8 1/4
dasol7172
5:05 PM
SC
Morning all. So I am putting a super rusty 72 sat back together and I managed to break the fitting on that rear brake body line right at the part that connects to the rubber hose Y block that sits in that bracket.
Whats the lowest cost solution for me on this? Can I just double flare the new shorter body line and put another 1/4 brake fitting on it or do i have to replace the entire body line? I have been looking through amazon, jegs and summit to find brake fittings but they all have a much shorter nut on them than the one that came off the line.. does it matter? can I use any fitting as long as its the proper size and the line is double flared correctly?
I bought a couple spools of nickel copper alloy tubing off amazon, its strong and DOT approved. Also can bend by hand. It made fabricating new brake lines a breeze
I used Finelines, no problems. I bet Dr Diff gets his from them.
So there is no way to just find a new fitting and use the current brake lines? Not looking to replace the current lines or spend much more money on it.
I think You need to post a picture of the damage for someone to determine what needs to be done.
Here we are. First is the end that broke that connects to the rubber Y block hose and the second is the fitting itself.
If the original line is in good enough shape to flare, is long enough to reach, and if you can successfully remove the armor all you need is a tubing nut-from any auto parts store.
Ok great. i wanted to try that first before spending 40 dollars and hours messing with rusted clips to replace the whole line. Just wasn't sure if the brake fittings I see work since the nut part is much shorter than the original.
You'll need to find a good place on your line to cut, double flare and attach a new piece to it. Right there where it broke looks very rusted and thin.
