Ground jumper for fuel tank/gauge
I don't think my car ever had one. Will soon! $10 on eBay. Search for: "Mopar Fuel Sending Unit Ground Strap"
Here is a picture of a real setup to support Nachos diagram, I only wish I knew where I got the new sender with the correct curved pipe, because I had the same problem when I restored my car, I could only find ones with straight pipe out, but I found this one and unfortunately its not in my parts spreadsheet! Also just to note, I never have had any issue before or after restoration with the ground clip.
I found one and just came the other day, along with some bushings for the column shift down by the tranny, not sure how long it is.
I never realized the ground strap was necessary. When I replaced the fuel tank in my 73 Charger before the resto began, I forgot to install the ground strap. Never had an issue, fuel gauge worked just fine.
