Frank2304
- 4:32 PM
- Apr 20, 2016
I posted this in the engine and driveline section but not too much response so far. Hoping for more input here in the general forum... thanks!
Hello, I have a 1967 Coronet with a 400 and a 1972 Duster with a 440. My question is regarding big block 440's and since I am a member of both FABO and FBBO, I thought there may be more 440 enthusiasts on the BBody forum so here goes...
The 440 in my Duster is a 1975 from a New Yorker. The engine is basically stock with the following mods:
TTI Headers and 2 1/2" exhaust with an H crossover
Edelbrock Performer dual plane intake maniford
Edelbrock Performer Series #1412 800 CFM carb
MOPAR P4452783 cam. 268/284 duration, .450/.458 lift (basically a stock 440 Magnum purple cam).
Mopar orange box/electronic ignition/ pointless distributor. (Initial 20*, 36* all in at 2,200)
727 Torqueflight
8 3/4 Sure-Grip with 323 gears.
I mostly cruise, attend car shows and of course an occasional A to B on the avenue but not planning on the track (OK, maybe once to see what kind of numbers it will do). I run it on 90 octane ethanol free pump gas. The car runs great as is but I know there is more potential power that is fairly easy to gain from better heads.
My question is this, I am planning to upgrade from my open chamber 8.2 to 1 stock heads and install some closed chamber, better flowing heads. Do I go with some freshened up closed chamber 915 cast iron heads and maybe a port and polish... OR... do I go with a set of after-market aluminum heads likeEdelbrock RPM, Source, Indy, ProMaxx, etc.
Keeping in mind I want to increase power of course, but don't want to select heads with a level of built in performance that would be thrown away on this relatively mild 440 build and cam.
Thank you in advance...
727 Torqueflight
