Need help to choose right Radiator for 68 charger w/426 Hemi
Mopartank
7:33 AM
new orleans, LA
Hi guys, I need a advice to choose right radiator for my hemi, I want to run it cool as possible in traffic. Thank you.
Specs
68 charger
426(472) 850 carb.
727 trans
Wizzard 3 row aluminum, make sure pump vanes are within .065 to back of housing. Use a Milodon Thermostat. Install a bleed petcock in block and also in top of Water pummmp. Clutch fan, with shroud. Blade edges must be 3/4 inside shroud and no more than 1/2 gap between blades and circumfriance of shroud opening. Skip all electric fans, make sure you have gaskets around underside of radiator to radiator support and top of Support to radiator.
Glenray is fan-freaking-tastic. I had a really nice 4 row aluminum (brand name withheld, but I paid $$$ for it and the fans) and my 440 always ran hot. The Glenray has been outstanding and I couldn't recommend it more than any other product I've used for a Mopar!
We've been a sponsor since the Winter and would like to offer B-Body members a special price to try out our products and report back here on the Forums. If you are interested, shoot me a PM or e-mail.
Chris
chrisc@maxperformanceinc.com
I went with a US radiators 4 row triple pass copper brass, Glen Ray actually spec'd it out for me but wasn't interested in building it. I had to order it through Classic Industries once I got the part number from US Radiators...it going in my 68 with a 572 hemi. Tim
Get ahold of Bob at Glenray. He will build you a factory appearing unit that will run cool.
I do have a used for less than one summer 4-core that fits a 66-70 B-Body copper/brass if you're interested.
Thank you guys for quick response. Cris, thanks for the offer, I ll check the web side and get back at you.
Took out a 26 inch inch stock tank with high efficiency core and bought an Afco 1 inch tube 3 pass for $200.Drove the car in the heat,160 stat and it was 180*
545ci blown hemi
Thanks strange. I don't remember telling someone I didn't want to make a radiator for them...ever. Please tell me more.
Thanks,
Bob
Glen-Ray Radiators
BTW,I only changed to save weight.Also installed an aluminum driveshaft:thumbsup:
How much is a 26 inch aluminum radiator Ccas?
Our radiators are Polished, stamped tank all aluminum, lifetime warranty and 60 day cool guarantee and retail for $369 on our website. Shoot me a PM with your application. Year, model, Engine size, HP, Inlet/outlet configuration, AT/MT and whether you plan on using your original fan and shroud or if you want to go with electric fan/shroud kit. If we have a good match, I'd like to offer a couple of Forums members special pricing so you can report back to the members your experience with Cold Case.
Chris
Thanks Chris,I would be interested in a better,skinnier,lighter double fan.I have a pair of pushers due to lack of spce between the lower blower pulley and the radiator.
