1969 1/ 2 idle solenoid for 6 pack - Question . . .
rb1970
7:07 PM
cincinnati
Does any one if a 1969 1/ 2 idle solenoid for 6 pack work on 1970 6 pack .thanks
Never had one darn it, but it should.
"part" as a title is not going to let forum members know what you need . . . if you want to get people to look at the post and respond.
I've edited the Title to make it more informative and helpful to the forum members - and I moved it to the proper forum for getting the best results.
Yes it will work for sure
Adding a little more info.... The 69-1/2, 70 & 71 intakes are the same (except 69 being aluminum), so the carbs are in the same position relative to the idle solenoid holes on the passenger side of the intake. All the solenoids have 1 wire going to them (+ side of coil if I remember correctly is the power source). There are only very slight differences in appearance that only a "numbers matching" guy would notice + some reproduction ones are pretty darn close too. They all will work.
Try member 62 max wagon he's a six pack wiz ... and my uncle
