SublimeSixpack
Personally I'd want to make sure the choke is operating as it should. With the engine cold I'd take the air cleaner off, open and close the throttle once and check the position of the choke. Should be closed or at least partially depending on ambient temperature. Then start the engine and watch to see if the "choke pull off" opens the choke at all. Of course I'm assuming your carb has a "choke pull off". If it does and is working correctly once the engine starts it should open the choke enough to keep the engine from loading up.
If not, I would think a repair or an adjustment is in order.
If that checks out, I'd open up the carb and do a visual. If today's fuel (untreated with a preservative) sets very long in a carb it can make a mess and cause problems. While in there make sure the float level is set properly, and that there isn't a problem with the needle on the seat.
Not everyone is comfortable doing carb work, but there are good manuals out there. And you have people here that are willing to help if you get stuck on something.
Just food for thought.
