FOR SALE 69 Charger
gsniegow
New Member
10:23 AM
Aurora, IL
Originally a B5 blue White Hat Special car. Body, paint and white vinyl top were applied in 2011 to preserve the original look as it left the factory. Rolled out of the factory with a 383. Currently has a Muscle Motors 400/470 (http://www.musclemotorsracing.com/) that was built and installed by a professional in 2015. Sitting on the top end is a Edelbrock Intake and Heads. Comp cams cam and a QuickFuel carburetor. TTI Headers. Transmission is a rebuilt 727 torqueflie in 2014. DriveShaft is a Chrome Moly driveshaft in 2014. New electric wiring run in the dash and the engine bay in 2012. Each year I have been updating something new on her. Just about all of the major aspects to the car have been updated. Late in 2015 I suffered from a medical issue which has halted progress on her and she has seen very little road time since (maybe 150 miles).
MuscleMotors dyno'd the block at 611ft-lb of torque 547HP at the crank.
List of new parts in 2014
* Edelbrock Performer RPM heads
* Edelbrock Timing Chain
* Edelbrock Performer RPM Intake
* Quickfuel Carburetor
List of new misc parts added when rebuilt motor was installed in 2015
* Water Pump
* Water Pump Housing
* Power Steering Pump
* Belts
* All brackets new
* Valve covers (Mopar performance)
* Battery Tray
* Griffen Radiator
* Coolant catch can
* K&N Air Filter
* MSD 6AL box
* MSD Ignition Coil
* Starter
* Firecore Distributor
* Firecore wires
List of new parts 2017
* PowerMasterAlternator
* Dual SPAL electric fans
There are still areas that need some work. Here is a list of items that I had on my short list to work on over the next few years.
* Glass is all original to the car. Could use replacement
* Front bumper is slightly bent. Chrome showing age on front and back.
* Speedometer / Odometer is not working. I don't know why, could be a cable or gear or something else.
* Currently has disc brakes in the back and drums on the front. Would eventually put disc all around.
* Dash is original and can use some freshening up.
Asking $45,000
She's a beauty - what are the original miles?
Honestly have no idea. These odometers maxed at 99,999 miles so I have no clue if or how many times is rolled. Further the speedometer/odometer has not worked since before I purchased the car. I can say the motor only has about 150 on it.
