Ski 61701
- 4:20 PM
- Nov 21, 2016
- Bloomington Illinois
Ok, now it sounds like you are narrowing things down. If you have a vacuum gauge hook it up to a good vacuum source, probably where you plug your pcv valve hose to. See how the needle fluctuates. Im sure there are charts on the web that will show you if you have X for vacuum look at timing, leaky valves worn rings etc. You might be on the way to figuring this out. Kudos to you for sticking it out and trying to solve the problem.
