15 volts running & idling. What's wrong?
70Bronco
11:54 AM
Indiana
66 Belvedere II 361. I'm getting 15 volts to the volt gauge, battery, & everywhere else. Installed new volt regulator, it has good ground, and I'm still getting 15 volts. The green wire on the regulator registers 8 volts, everywhere else: 15. Where do I look now? How do I diagnose this?
14 is normal.
Look for a voltage drop between the positive battery and the blue lead at the regulator. Connect a volt meter leads between them, post results.
you probably have one of those new electronic regulators. with those 15 volts is about normal. the mopar blue electronic will give a little less.
15 volts aint that bad. I was running at 14.8v for a long time, and then when I added engine grounds for some reason it dropped to like 14.2-14.3.
Are you testing with a digital meter? If not the gauge could be that far off.
Mine shows 15 with an aftermarket gauge and the new fangled solid state regulator. Been driving it that way for over a year now with no issues. Now I will have to check the voltage at the battery with my DVOM. Will report back in a bit.
Gauge is only off a couple tenths. I checked with a voltmeter. Running 14.9-15.1 everywhere.
So, then you’re guessing the voltage drop is around .2 of a volt? Really need to measure it if you want to accurately isolate an elevated charging voltage condition. Again, place one lead at the regulator Batt. terminal (terminal, not the connector/plug) and the other at the pos battery terminal. If it measures .2 of a volt, that would be fairly low for a fifty year-old electrical system, with a good battery, that would leave the regulator as the only issue.
You can also run a temporary by-pass jumper from the battery straight to the regulator terminal, see if the voltage lowers a bit. Careful not to short anything in the process.
Not to be alarmed! When you first start the car there is a draw on the battery that needs to be replenished thus the higher output. Mine does the same thing but after a bit of constant driving, drops to about 14.2. This occurrence can vary depending on weather your using an AGM style of battery or Lead-acid. The real issue here is weather or not the alternator/VR can maintain a decent output with all the power "hogging" circuits activated.
How many grounds are on the car and are they all clean under the ground screws etc? Imo, the factory didn't use enough of them....
It looks like you have the old style breaker point type regulator from your picture.
I suspect the breaker points are welded closed, so you get full charging from the alternator (no regulation). This will overcharge the battery and create a strain on all the components. You should able to remove the cover and visually inspect or just disconnect one of the wires to it and check for continuity. You may be able to just clean up the contacts or replace with a new one or a solid state replacement. I think I have one somewhere... Good luck, nice car.
OOPs just read again you had already replaced the regulator. Sorry, probably the alternator but I've never heard of 15Volts? What type of battery are you using?
Sometimes the old mechanical regulators are adjustable. I was schooled that 14.6v is ideal charging voltage.
there are new electronic regulators out there that are made to look like the old point regulators. I use them and they will do around 15 volts.
No, I'm getting the same reading at VR and battery: 15 volts.
You asked specifically how to diagnose an overvoltage condition. Voltage drop at the bat terminal on the regulator is the first thing to be checked. It needs to be measured as previously mentioned. There is no-way your 50-yearold original wiring has 0 voltage drop through the bulkhead connector twice, wiring, ignition switch and it’s connections. If you are not going to measure it then your only option is to throwing regulators at it in hopes of finding one calibrated at a lower voltage or open one up (voiding any warranty) and make the mechanical adjustment mentioned.
Has the voltage at the alternator been measured? There should be a slight difference between that and at the battery as mentioned previously.
