65RoadRacer
I've installed intake manifolds before and tossed out the front and rear foam/cork seal and just ran a thick bead of Ultra Black. Seemed to be easier to deal with because the seals sometimes move when you're laying down the intake.
So I was thinking, maybe 'glue' down the end seals with Ultra Black and let that set up, then run a bead on the top and lay down the intake.
What do you guys typically do? (I have a different gasket set, not this one with the metal gaskets). Thanks!
