Looking for Mopar Mechanic in Chicagoland area
Kind B
6:03 AM
Earth
Heys guys looking for someone to help re assemble my 1971 roadrunner, work that needs to be done: put in back glass plus trim, put in rear side windows including trim and drip rails, put in dash and hook up electrical to it, put on front bumper and grill, align fenders and hood and grill.. thanks guys
In going over what you want / need to do, anymore these days, these things kind of fall under a resto shop doings.
Are you looking for a fellow member to help you to reassemble the car with you?
If not, you are more than likely going to be stuck utilizing the services of a resto shop as Purplebeeper mentioned, and unfortunately going to pay a pretty penny anymore.
I know time is tight with people, but what you've outlined it's not hard, just cumbersome, hence needing an extra set of hands to help. A FSM is your best friend here, you be surprised how simple things are after reading it. If I didn't live so far away, I'd stop to check things out with you.
Also, you might try Safelite or some other "regular old" windshield replacement place for the back glass. The bumper you can probably do yourself. Dash & electric definitely a restoration shop. Aligning body panels, "maybe" a regular body shop, but most of them I found in Chicagoland wouldn't touch my car at all.
I know a Mopar guy (in Roselle I believe). He does mechanical work and is well known and respected by everyone I run across at car shows, but I don't think he does body work.
