WTB 66 Satellite drivers door trim
Dennis361
6:36 AM
Central Oregon
Need upper exterior door trim for my 66 2 door hardtop Satellite. Can make the door trim from a good drivers quarter trim if necessary as long as there are no dings in trim piece.
I you referring to the belt line trim? and which side? If so I have both a NOS Rt Side and a Used...cr8crshr/Tuck
Oops! Yes for the drivers door. The trim I'm referring to is the stainless piece that sits above the door handle at the top of the door and approx 3 inches from side window. This 3 piece trim runs from the top of the front fender, door and rear quarter. Only Satellites had this trim. The Belvedere trim was located midway down the side of the car.
OK the left side is original used piece. Will that work???cr8crshr/Tuck
Yes that should work fine if it is dent free. My existing piece has two small kinks that the shop cannot repair without polishing the anodizing off to repair. They said if I cannot find a straight door trim then to look for a straight quarter panel trim piece and they could cut one from it and make it work. Do you have a pic of it you could send me along with price? I live in Bend, Oregon. Thanks!
Got pics available but I need your email address so I can send you the pics as I cannot do it here using the PM feature. PM me with it if you would I am PMing mine right now...cr8crshr/Tuck
