1967coronet440
Should take care of your idle issue.Awesome, thanks. Just what I needed.
That might solve the whistle noise also, since the idle air control numbers are off it probaly has the butterflies closed too far at idle
Where’s the videoYeah were right on. with the air cleaner off it got louder and by ear, it was clearly coming from inside the throttle body. I changed the gasket anyway, the one they supplied was like a piece of Masonite.
IAC is supposed to be 3-10 at warm idle, mine was at 147. Plus my throttle linkage was a bit off. Little adjustment and 1/2 turn on the throttle screw and the idle cleared right up and IAC is at 7-10.
Kinda cool, at this point it has 10 min of idle time and maybe 10 miles on it. You can hear the ecu hunting and pecking and you can see the learn % going up and down... pretty neat stuff.
Maybe the best part...
First time in 5 years that fuel gauge read full.
alot of people have issues because they mismatch the parts, and don’t read the manualGood to hear it's working out for you. There is a Fitech group on Facebook, seems to be a lot of problems there. Some I think are from installation issues.
What are you running for ignition? MSD dist?
Where’s the video
grasśy asšMy phone took a dump... mucho video mañana.
@1967coronet440 I'll tell ya something, your info on IAC got me to do some research. I think I'm gonna have fun tweaking this thing, at first I figured it was more plug and play but some adjustments will definitely need to be made.
Question about IAC... It's at 7-10 or so now at warm idle and climbs into the 50's on acceleration, not WOT, maybe half a pedal.
Normal?
I can’t wait to get mine fired up and get it tuned up, pretty jealous right now. As far as I know that IAC ( Idle Air Control) is basically like your base tune that Jd to be correct for the ECU to make the proper corrections/adjustments from there. Did you notice the throttle response get better once you got the IAC set properly
HT413
I know you're using the Fitech intank pump. How is the rest of the system plumbed? If I remember correctly, the Fitech pump has a built in regulator. So all you have to do is run a supply to the throttle body. No return back to the tank because the regulator is on the pump. Am I correct?
Got the fan controller squared away, works great, though the idle is still pretty up and down... much more so than the carb.
