- 10:08 PM
- Dec 14, 2008
- Long Island,New York
What you see on those plugs means next to nothing.You need to do a proper plug reading and post those up.
will do tomorrow..as someone has said though already,,,California unleaded pump gas is hard to read...what started all this was the shroud that I put on the rad with electric fans that made it run hot..driving down the road at 50,barely pushing the gas peddle,,the temp gauge would start moving up and it would start pinging.did not ping before.....then,realized with more reading that I was severly under jetted and the metering rods / springs need attention...anyway...to be continued tomorrow.will get after it in the a.m...thanks..What you see on those plugs means next to nothing.You need to do a proper plug reading and post those up.
I've discovered getting older cures detonation. I don't hear it as much as I used to.sometimes ear plugs and turning the radio up diminishes detonation.
